-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   What's Inside Silent-Thunder Exhaust? (https://www.offshoreonly.com/forums/formula/76409-whats-inside-silent-thunder-exhaust.html)
ApachePete 04-11-2004 01:18 PM
Specifically, is the exhaust from both pipes in an engine dumped into a common chamber?
I ask because the transom on the port side, around both exhaust outlets, is suddenly black with soot. The motor run and sounds just fine. HP500EFI's
I was wondering if it could be stuck injector, dumping too much fuel in one cylinder. But for that to be the problem, the exhaust from both cylinder bank would have to intermix.
Any ideas?
Thanks!
ApachePete 04-11-2004 02:09 PM
Officer
You certainly are a very knowledgeable guy!
Thanks for the info.
I wonder if the cross-over is big enough to allow soot to build-up equally around both exits pipes, if only one bank of cylinders had a problem.
Perhaps more likely the whole system is running rich?
ApachePete 04-11-2004 02:12 PM
Thermostat
Water temp is normal (150), BUT last weekend it was up to 200 briefly after I sucked-up some sand. I replaced the impeller, and temp and oil pressures are normal.
Would an overheat cause on over rich condition?
Bill272 04-11-2004 08:10 PM
1 Attachment(s)
Here's what mine looks like from a 95 336.
Formula Outlaw 04-12-2004 07:41 AM
On my 89 311 SR-!, a bolt on model, it is nothing like that. Mine is just one big box, with "partitions" glassed in place in front of the rectangular exterior exhaust outlets and in stock condition, small circular holes at the bottom of the box, which are under water when the boat is not on plane. I cut those little circles into big honkin' rectangular holes, and when I look up in there I can see all four very "thru hull" short exhaust tips. I also cut out the partitions. I ended up gaining 300 rpms on the top end by doing this. Sounded better too, not obnoxiously loud, just throatier and more powerful.
jaybird 04-12-2004 08:39 AM
Those little circles that are on the bottom of the "1st Gen" Silent Thunder platform are for inserting drain / baitwell style plugs into. You pull them out to drain after usage or winterization. From what I have been told, keeping the plugs inserted is the way Formula designed the platform to run with water in it to help keep it cool so the platform doesn't overheat and start to deteriorate.
I run with the plugs in, as did the previous owner. I just took the platform off to fix an exhaust leak, and the insides of the platform were in surprisingly good shape for it's age.
Formula Outlaw 04-12-2004 10:56 AM
Jaybird, I didn't know that for quite awhile after I bought Outlaw and did the exhaust mods. For a few times afterwards, after running at higher speeds for extended periods of time, I would physically feel the box to see if it was hot, and it was warm, but not even real warm, much less hot. I would suspect cutting out the partitions helps that heat issue as I now have a lot more water blasting out of the rectangular holes than I ever did before, and if the water is blasting out more it would make reasonable sense that the exhaust gases are also. I constantly check the "raw" edges where I cut to check for deteoriation but so far none whatsoever.
WAGS382 04-12-2004 08:15 PM
Apachepete
I just took the silent thunder off my 1998 382 and it looks very similar to Bill272's, but it also has the balance tubes that Troutly mentioned. I put a set of HPI silencers on, I don't like the sound of the silent thunder.
ApachePete 04-12-2004 10:01 PM
WAGS
How does the "loudness" compare?
Bill272 04-13-2004 12:17 AM
I took mine off because I was getting an exhaust leak around the edges of it and it rattled. When I looked at it, there was a couple of cracks in the chambers and the one edge was split (where the white kind of moon-sliver spot at the bottom of the pic is.) Where the white spot is also rubbed the gel off the boat under the swim platform there on the side facing the center.
I took it off before the last run of the season and thought the boat was fairly loud before (hp500's). Without the silent thunder, it's considerably louder. I didn't think it would make that much difference since the exhaust exits under the swim platform, but it is a very noticable difference. I like it personally, but I'll fix the cracks this summer and keep it in case they start writing noise tickets around here.
Where do they put the balance tubes on the newer ones??
Formula Outlaw 04-13-2004 06:50 AM
I also have it on good sources that Troutly used to keep "Pictures" hidden inside his silent thunder for "emergencies". :D :D :D :D
RUSSSR1 04-13-2004 12:49 PM
For people that want to see the inside of the SR1 silent thunder I will attach a couple of photos. I removed mine because the hull platform gasket was leaking as well I had some cracks at the tow hooks. What I found was the backside was completely rotten. I cut all this out and glassed in a new piece. the job was relatively easy and now I have no leaks or rattles.
RUSSSR1 04-13-2004 12:51 PM
1 Attachment(s)
Tow hook cracks, if you have them I would look for rott in your platform.
RUSSSR1 04-13-2004 12:54 PM
1 Attachment(s)
Area of rott that I cut out
RUSSSR1 04-13-2004 12:56 PM
1 Attachment(s)
Good inside shot of the parition that many people take out
WAGS382 04-13-2004 09:10 PM
ApachePete,
I haven't run the boat yet with the new silencers, I'm shooting for the 1st of May. Jeff
ApachePete 04-13-2004 09:24 PM
I'd like to know how the silencers compare to Silent Thunder in the "quiet-mode."
ThirdBird 04-14-2004 11:30 AM
Re: What's Inside Silent-Thunder Exhaust?
Any ideas?
Thanks!
We need to get this thread back on topic. The original question involved sooting at the "transom".
Is the soot showing up at the actual transom or at the actual exhaust outlets in the silent thunder platform?
If its at the transom (where the exhaust chamber mates-up), then you have a leaking chamber seal at the transom exhaust tip and at the peripheral seal. This is allowing exhaust gas to seep out without going out through the exhaust chamber. Some sooting is normal and if you have a leaking platform system, it will show up as sooting.
However, if you only see the sooting at the actual exhaust outlets at the back of the exhaust platform on one side and see no sooting at the other side (other engine), then there is obviously an engine problem. Could be anything from fuel delivery to spark to valves, whatever.
Got any pics?
ApachePete 04-14-2004 11:45 AM
Problem is heavy soot at the exhaust tips on the port side, which is so bad it covers one half of the underside of the Silent Thunder, as well as most of the transom below it. Problem began suddenly after I picked up sand and that engine's water temp went to 200. Still runs fine, power-wise.
Seems that the water temp sensor could have been clogged or damaged, telling the motor it hasn't warmed up yet, so it goes into an over-rich mode.
Haven't found anyone with a scan tool, so I'll switch the sensors between motors and see if the problem goes to the other one.
Any other ideas? Are these sensors prone to problems? I've picked up sand and overheated MANY times, but never had this problem before, so I'm not sure it's any more than a coincidence.
