-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   382 Fastech (https://www.offshoreonly.com/forums/formula/78420-382-fastech.html)
Hydrocruiser 05-05-2004 06:51 PM
382 Fastech
I am interested in info on engine combos and speed with them.
For example:
HP 500's and it's speed
HP 525's and it's speed
Thanks.
Rippem 05-05-2004 06:56 PM
welcome aboard! You will find all the info you're looking for in regards to performance boating right here! :) A number of 382 owners and/or Robert Nelems (Magicfloat on this board) can fill you in. Robert is a premier seller of FasTechs. ;)
Hydrocruiser 05-05-2004 07:01 PM
Yes. Thank you.
Appreciate the help.
restabr 05-05-2004 09:06 PM
Definitely get in touch with Magicfloat. I bought an 04 353 from him. First class operation. The deal was simple, straight forward, super competitive and everything was as agreed. Troutly, another board member, bought a 382 from Magicfloat.
Good Luck!!
Formula Outlaw 05-05-2004 09:34 PM
Troutly is also the world's authority on:
"LESBEFRIENDS":D :D
Also damn smart on Formulas.....:cool: :cool:
OffDuty 05-06-2004 12:43 AM
1 Attachment(s)
I just finished retro fitting a 2002 382 Fastech. Teague 800 Mills. Arenson/Bravo conversion kits last week. Holy **** 106 gps. 6 to 7 mph fastewr than Bravo's that blew up 6 times. This boat weighs in loaded at about 12800 lbs. 60 to about 95 is done in about 4.5 to 5 secs. Better speed and no more broken Bravos.. here are some pics or chek out his site www.arneson-industries.com And check out boat on their site. This boat is on the site under bravo converison
OffDuty 05-06-2004 12:53 AM
1 Attachment(s)
More pics
OffDuty 05-06-2004 12:55 AM
1 Attachment(s)
One more!!
OffDuty 05-06-2004 12:59 AM
1 Attachment(s)
Retry
CBlakeNS 05-06-2004 09:01 AM
Definatly a nice boat, tow rig is sagging though haha!
OffDuty 05-06-2004 09:52 AM
Friends truck. 3/4 ton lowered. Climbing onto the hwy headed to the ramp 2 miles away. Real truck is behind the boat in the pic. I know it looks bad:drool: Was already hooked up to that truck and first time in water after 5 month retro on boat. It was getting dark. To disconnect and connect to real means 10 mins less on the water:D Anybody interested in finding out about this system and costs ect. can call or e-mail [email protected]
OffDuty 05-06-2004 09:56 AM
Re: 382 Fastech
For example:
Thanks.
I ran a 2000 382 Fastech with all options incluing genset w/ 500EFI's labbed 30 bravo 4 blades turning out. Best speed 72.4 gps. Hope this helps
Hydrocruiser 05-06-2004 11:04 AM
Interesting stuff!
Steve_H 05-06-2004 06:09 PM
all that work just to pull a skier :crazy:
you guys are nuts ;)
almost forgot , stop playin on the puter and ship my trim rings :p
Formula Outlaw 05-07-2004 08:03 AM
Scott, there's a couple of 382's in the OPBA running the 500 EFI's, probably not as loaded down as yours, but they are in the high (est) 70's. With the way your boat is equipped, does that really slow the boat down 4/5 mph? I'm just surprised. Then again, I'm still on the "learning curve". :D Russ
WAGS382 05-07-2004 09:05 PM
Troutly,
What mufflers did you go with? I launched my 382 this week and I like the sound of the HPI's. I only drove the boat once with the silent thunder so I don't know if they helped the performance. I was happy with the top end 75-76 mph on the gps @ 5000 rpm with HP 500's, no boxes 28" un-labbed bravo one's. The boat does not hook up as good as I would like in the mid-range, 48-50 mph @ 3500. Do the p-5's have a better mid - range than the bravo's ?
Dblvanos 05-07-2004 09:23 PM
OffDuty
What did you do to that poor bravo?
what was the cost to do the arneson conversion, who did you buy the drives from, and did you encounter any problems?
John B 05-08-2004 09:06 PM
I made up a chart for a 382, see if this makes sense.
382 with 500's ---- 382 with 525's
light -- heavy ---------- light -- heavy
74 ---- 70 --------------- 78 ---- 74
add or subtract
_______________
labbed props +1 to +2
ITS +1
Stellings +2
Dump Corsa +2 (open exhaust)
on ITS and Stellings
Fresh water -1,-2
altitude -1 per 1000 ft
Hot and humid -1 to -3
This may be close and may help our brothers with their questions on top speeds, it seems pretty close to what you guys put on OSO.
RedDog382 05-09-2004 09:11 AM
Offduty,
Have been very interested in your conversion on your 382. Incredible performance with the Arneson's and cool as beans, too!
I heard they had to lower your engines 3 inches for the conversion. Doesn't seem like there is much clearance below the motors on my boat. Does that leave the oil pans right on the bottom of the bilge?
I'm running 645 H.P. Sterlings in the '99 Poker Run Special. Just found a toasted XR drive, but I think the damage was from the previous owner's heavy hand on 950 H.P. motors.
Any experience with Max Machine Worx drives? I think they may hold up to 650 H.P. and some tender touch on the sticks. PM me re: Max if you would prefer.
B.T.W. What are you "Offduty" from ... medical, law enforcement, or otherwise?
Chris
cuda 05-09-2004 10:48 AM
I for the life of me can't figure out why more surface drives aren't on these heavier boats. 106 is smokin'!
Magicfloat 05-09-2004 11:30 AM
John B's chart is best I've seen.Thanks,John,it will go in my file. Robert
OffDuty 05-10-2004 12:01 AM
Engines are about 3 " lower in bilge at rear and 2 " lower in front. I installed 4 inch Teague oil coolers on middle stringer under both engines. Tight but fit good. All other rigging is same as bravo setup but reworked to fit Arenson setup. 4 L brackets to install motors. System is about 17500 per side much less than #6 drives(31000$ per side) and CG stays the same. Boat did 99 to 100 with Bravo's. 170 hrs on Bravo's and 6 breaks. Boat now has 10 hrs on drive and everything looks good so far.
