-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Single or Twins? (https://www.offshoreonly.com/forums/formula/78893-single-twins.html)
Prater 05-11-2004 11:28 PM
Single or Twins?
OK, I am starting to plan what I will be doing with the 255 Liberator. Should I keep the currrent single configuration, or should I replace the transom with dual I/O. I know the later will be quite a bit more expensive, but would it be worth the effort in the long run?
Audiofn 05-12-2004 06:41 AM
Stay single. It will be to much work to put that thing together with twins, plus the boat is really to small for twins, even small blocks. You will not gain much in the speed department with twins and the boat will weigh a LOT more.
Jon
kaamaman 05-12-2004 07:10 AM
I'd have to agree with audiofn, stay single too much $$$ and lots of structural glas work would have to be done.
here's one on ebay: item#2477867035
Formula Outlaw 05-12-2004 07:58 AM
Upgrade to a boat with twins.
mopower 05-12-2004 08:45 AM
It's easier and cheaper in the long run;)
Prater 05-12-2004 08:50 AM
thanks, i will stay with the single and upgrade later.
mopower 05-12-2004 02:09 PM
I did consider doing the same thing to my 211 Liberator BUT I was going to remove my 540 and bracket mount two big outboards. Then make the engine hatch half the size , add another gas tank and move the rear seat back to attain a bigger cockpit and twin reliability:D
Talked Mama into a bigger boat instead;)
