-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Fridge Door ..?? (https://www.offshoreonly.com/forums/formula/80388-fridge-door.html)
offthefront 06-01-2004 09:32 PM
Fridge Door ..??
what keeps the Fridge door closed on a 311 ? There is a little bar that is on outside door ....that coupled to fridge door ? Pics ?
Formula Outlaw 06-01-2004 10:05 PM
Re: Fridge Door ..??
Mike, I'm seriously considering taking my fridge completely out. In three years I've never turned it on, hell I don't even know if it works. I always bring a cooler. Guess old habits are hard to break.
Does anyone else use theirs. I suppose Troutly does since he's got the gen set on that new 38 FasTech. Probably has a lighted "disco ball" down in the cabin too.
ThirdBird 06-02-2004 05:59 AM
I believe it's just held by magnets inside the door seal. I've used mine a few times. Takes a long time to get it cold but once its cold it doesn't take all that much battery to keep it cool.
Dave
offthefront 06-02-2004 10:28 AM
It doesnt stay shut at all ...and there is a arm on the outer cabinet door ..that looks like it could attach to the hole in the upper right outside edge of fridge door ..So every time you open the outside door it would open the fridge ...which doesnt make any sense ..I'll get a pic ..
offthefront 06-02-2004 10:29 AM
Where is that Switch for the Ball ?? :D
jaybird 06-02-2004 02:43 PM
Yep, that's what keeps the door closed. Works fine on mine. The stock fridge is a Norcold, so if you wanted to update the latch system you probably could buy parts. However, my friends boat that uses a lock pin to keep the door closed always flies out, and then you've got alot of beverage lying on the floor all shook up. I think the Formula design is a decent one.
