Fuel tank sender F223
The VDO fuel tank sender on my 88 223 is pretty well crapped out, it had been getting stuck alot, and on my last cleaning attempt I broke one of the float wires.
Its the tube type sender, 8 11/16" tall with 82/8/21 stamped on the top, I actually had the VDO catalog from 1988 and found the part number to be 224-061. (why the part number isn't on the part I'll never understand) I found it online for about $75, but was told 2-3 weeks before I could get it. I think this is a 90-0 Ohm sending unit, any chance I could pick one up in an automobile flavor? or do I have one of those bass-ackwards VDO gauges that is different than everything else? |
Re: Fuel tank sender F223
Its the tube type sender, 8 11/16" tall with 82/8/21 stamped on the top, I actually had the VDO catalog from 1988 and found the part number to be 224-061. (why the part number isn't on the part I'll never understand) I found it online for about $75, but was told 2-3 weeks before I could get it. I think this is a 90-0 Ohm sending unit, any chance I could pick one up in an automobile flavor? or do I have one of those bass-ackwards VDO gauges that is different than everything else? http://www.gilmoredist.com/vdo-marin...ccessories.htm |
You can replace them with the Gaffrig unit if you want to.
Jon |
Originally Posted by chuck21401
Check out this link, references the number stamped on the sender and the part number. BTW, I need a sender for the tank in my 89 242LS, anyone have the part number?
http://www.gilmoredist.com/vdo-marin...ccessories.htm Well I cleaned the sender today and I was reassembling everything the float wire broke. But I did get the numbers off the unit: 82 5 137 which translates to VDO part number 224 064. |
If you're lucky enough to have VDO guage you are STUCK using VDO sender. The Gaffrig won't work with VDO. They used non-standard ohms range and even Gaffrig with special wiring will not work.
Been there/lost that battle and just got correct ohm sender. |
I upgraded my entire dash from VDO to Faria for this reason, and I also got the Hardin Marine Sender (which has no float). It works great! (Plus I hated the VDO 'look'.
The guage is only a guide. Do yourself a favor and buy a fuel flowmeter. They are bal$$ on accurate and don't usually break. -Larry |
Originally Posted by ljsmith1
buy a fuel flowmeter. They are bal$$ on accurate and don't usually break.-Larry
Upgrading an entire dash sounds expensive. I wish I could find a junkyard for mid-80s - early 90s Formulas. |
FYI, this company no longer stocks these senders, the info on their website is now "informational" :(
http://www.continentalimports.com/vdo_send_fuel.html These guys don't stock part 224 064 (as it is out of production), so I ordered 224 063 ($77.53), which is a little shorter (12 1/4 vs 13 7/16). From what I understand the gauge will always read a bit low...I guess a pessimistic fuel gauge is better than an optomistic fuel gauge. http://www.gilmoredist.com/vdo-marin...ccessories.htm Also, unit is special ordered from Germany...3-5 weeks. |
| All times are GMT -5. The time now is 11:24 PM. |
