-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   311 Engine Hatch Won't Lift (https://www.offshoreonly.com/forums/formula/84390-311-engine-hatch-wont-lift.html)
Formula311-SR1 08-03-2004 03:58 PM
Re: 311 Engine Hatch Won't Lift
I had the same problem with mine yesterday. Once I cleaned out the dried clumps of grease it worked like a charm. Of course that was three hours later in the dark, but it's fixed. Once I got the screw jack to release it was easy form there.
mcollinstn 08-03-2004 08:32 PM
Shouldn't hurt it to ratchet it on the bottom of travel if greased properly.
Trolling plug may not be "sparkproof". Careful using it so close to fuel pumps/lines.
wantsa311 08-03-2004 08:53 PM
Problem solved. I followed Iggy's instructions to take it apart and clean it and it's all set - works like new. The grease wasn't all hard and dried out but the shaft was really jammed down on the gear. I guess it's just a "feature" that you learn about thru experience. Thanks everyone !!!
Iggy 08-04-2004 11:28 AM
Good job!
Now you'll know what to do next time. :D
