single step - double step
looking to move up, the ex., has a single step square windsheild, ice box, port potty ect., I realize it is a cheaper boat, 2 things, why, wouldn't be cheaper at manufacturing to go with one bottom .With the same power are the boats same speed because I assume the double step boat is heavier
with fridge pump out head ect, JMPH |
Re: single step - double step
Not sure of Ex #'s our 05 Lightning TS with 500's is 84+ with 1/2 tank and 3 on board for comparison.
Single step 35 runs around 80 with 500's -2nd step good for 3-5 mph
A twin step is substantially more efficient. A bigger step is substantially more efficient. About 20% higher Crouch constant. A non-step bottom is typically 160-180, a single and small and/or poorly designed step bottom is about 200, while the latest Fountains are about 240-260, far better than other boats.
Here is the formula, plug in for your boat, and you'll see what I mean: (from http://www.cs.uu.nl/wais/html/na-dir...faq/part3.html) The formula yacht designers use is called Crouch's formula. It takes into account the weight and horsepower at the propeller, and assumes a 50"% to 60"% efficient prop. Most props fall into this range. Note that it doesn't take into account the boat length, as that doesn't matter with planing boats. Crouch's Formula V = C/((DISP/HP)**.5) Where V = boat speed in knots (1 knot=1.15 mph) C = Constant (depends on boat type) DISP = Displacement (pounds) Note that boat manufacturers usually give innacurate numbers for displacement, typically on the low side HP = Horsepower available at the propeller For comparison sake, here are some average values of C: 150 Typical lightweight, planing cruiser 180 High Speed Runabout 200-230 Race boats, hydroplanes etc. |
:confused:
why would fountain make 2 bottoms, why not use same bottom for bothe boats, 3-5 is alot
JMPH |
The answer might be a couple things. I do know that the TS is 3-5 mph faster, but the single step will out handle it and turn harder. The two bottoms is probably because customers like choices and that is just another option they have.
[QUOTE=u4ea32]A twin step is substantially more efficient. A bigger step is substantially more efficient. About 20% higher Crouch constant. A non-step bottom is typically 160-180, a single and small and/or poorly designed step bottom is about 200, while the latest Fountains are about 240-260, far better than other boats.
I think the new Fountains are more like 280-300's close to cats.. ..that means it's a great straight line boat....if you catch my drift. :D How's that for start'in some chit in the "Fountain Room". It's fine as long as you know what you are getting into....wanna hang fast tight turns without sliding and risking a spin-out??...160-200 and more power and lesser speeds...of course....faster through rougher water most definitely...need a heavier old school Cig.... :rolleyes: Who me comment on steps? Darn it all I want speed without steps.... :drink: In reality I love hanging really fast turns..always did...I must be waiting for GLH to sell his Tiger to me or something :eek: ...give me one Fountain and one Cigarette please.... :D You know I love you Reggie :D but old school was great and new school is great and there is a price to pay for a 300ish V-Bottom stepped hull in terms of turning quickly if need or want be and of course there is a price to pay for a non-stepped or less radically stepped bottoms... |
Bigger motors over comes all that :cool:
But in reality it is good we have choices.... IN some ways I wish steps were never brought back in vogue. If nothing else they break up the lines of a boat.... But I am a knob...been here and done this...wish some companys offered 2 versions. :D Yup bigger motors...like 1050 Sterlings and a 42' non-stepped Cigarette. Why can't I give this up? :p |
By collecting data from boat tests, I find the following constants. NOTE that the constants are sensitive to weight, and as fas as I could tell, all the weights quoted in all boat tests are provided by the manufacturer -- the boats were not weighed by the publication doing the test. Therefore, these numbers are not precise: 1992 Fountain 47, no step: 209 2000 Fountain 47, two big steps: 277 2006 Fountain 47, slightly improved bottom: 284 The early boat needs 50% more power to reach the same speed. That also mean 50% more fuel. Very similar big double stepped bottoms: 2001+ Fountain 42: 267 2000+ Formula 383: 267 2000+ Cigarette 42 Tiger: 258 My boat, single but pretty big step: 2000 Fountain 32 Sportfish Cruiser: 245 Non-stepped bottoms: Baja 442: 237 Excalibur 47: 236 Big fat tubby powerboats: Cruiser 405: 200 Playing with the numbers to compare my fuel burn this weekend with a theoretical identical boat with no step, and two steps: No step: $275 One step: $235 <- actual Two step: $215 |
Dan |
| All times are GMT -5. The time now is 10:57 PM. |
