-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   cabin water leak (https://www.offshoreonly.com/forums/fountain/109249-cabin-water-leak.html)
FOUNTAINFAMILY 09-06-2005 10:48 AM
Re: cabin water leak
Had a 27. It leaked through the bow rail mounts. It came down behind the the header above the bed. It was a little tricky to find. Found it, sealed it.
carney 09-09-2005 03:17 PM
leaks Su-------------ks when you can;t find them
Daryl 09-20-2005 04:48 PM
Mine is also leaking but at at the wide end of the V berth. I think it is the windsheild.( 99 42 Lightning ) Can I just silicone the fastening screws?
kennorth 09-26-2005 07:59 AM
I have had a leaking problem for some time. I just found that the water tank had a small hole at the seam where it was welded. When the tank was filled more than 1/2 way it would slowly leak out - maybe 8-12 oz per day.
