38 fountain
need some info , did fountain build a fever and a lighting in 98, and are the hull's the same
thanks Joe |
Re: 38 fountain
thanks Joe |
Re: 38 fountain
thanks for reply, my buddy has a 95 47 lightning with wrap around windshield etc., and I really like that you can walk around the windshield than hop over windshield to get on bow.I am thinking about buying this 38 and second guessing it because of that.Do you know when the lightning was built. I realize the newer X have a walk around but only have single step.
thnks Joe |
Re: 38 fountain
THE FOUNTAIN (LIGHTNING) Hull was originaly the 10 and 12 meter Executioner.. and was named the lightning and stayed that way till late 99 when the first 38 lightning came out of the mold. at that time the executioner hull was renamed the classic deck the ex/lightning has always maintained that (Walkaround ). the 38 fever is a older mold and started back in 88 some as ICBMs in 8.8,meter32 foot and 38 and has never had a walkaround..the teltail is the lightnings have in one way or another had two features. forward faceing vents (Air intakes) and the walkaround
hope this helps |
Re: 38 fountain
JMPH, I would suggest that you get into the cockpit of both boats before deciding. I had a 35 ex and was ruined on it the first time I got into the cockpit of a 38 Fever - the extra room is considerable over the lightnings.
Personally, I would much rather go thru one of the hatches to get to the bow than hang over the side. But to each his own. The never 38 lightnings (2002 and newer I believe) have the bigger steps and are faster, but they are much more prone to spinning in a turn. It's give and take on both sides. Check them both out before you decide is my advice. |
Re: 38 fountain
Guy's thanks for the info, looks like I have some thinking to do
joe |
Re: 38 fountain
does anyone know when the bottoms changed on the 38, I realize the steps came in in 95, I think larger in 98, and I understand not changed till 02. Any help would be appreciated
thanks Joe |
Re: 38 fountain
I had a 32 Fever and now a 35X. I would never have a boat
without the walk around again. |
Re: 38 fountain
I assume the walk around takes room out of the cockpit, by the comments above but I still like the walk around for getting on the bow.
Re: 38 fountain
anybody know when they chaged the bottoms
thks Joe |
Re: 38 fountain
Went for a ride on the boat above 98 38 500.s carbed, really liked it, making decision this week, I realize the air vents for engine comp., are dated, thanks for bringing to my attention, but I would realy like to know if the botom is 2nd generation from the 95, I plan on pulling motars and updating heads and cam, had a second question 500 carbed come with gill and the efi come with tubular type exhaust, is the gill going to hurt me hp wise compared to the tubular typle, I think CMI. I must say big difference from my 32. any help appreciated
thks Joe |
Re: 38 fountain
CMI are the way to go, either CMI light or step into the full polished tubular, big difference. i believe the 98 hull is the same as 95, first generation but not 100% they changed on 2000 to second gen. sounds like a fun boat good luck.
Re: 38 fountain
Get the correct CMI's....There may have been water reversion probs with some of the HP 500's, check to be sure.
Re: 38 fountain
I think the revertion problem, came with the gill but not 100 sure and I know my 98 32 has larger step than a 95 32 thats why I was assuming the same for the 98 38
Thks for the replies Joe |
Re: 38 fountain
Does amyone know for sure
thks Joe |
Re: 38 fountain
cmis no reverion problems just make sure that if you run in brakish or saltwater that you flush them they tend to get pin hole on the inside welds if not
Re: 38 fountain
any one about bottom
Joe |
| All times are GMT -5. The time now is 11:00 PM. |
