-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Sport Master Short Case -2 (https://www.offshoreonly.com/forums/fountain/121869-sport-master-short-case-2-a.html)
Ran-Dom 32 02-09-2006 09:43 AM
Re: Sport Master Short Case -2
3380 each?? complete bolt on??
JaayTeee 02-09-2006 11:27 AM
Thats the price I got for complete units.
$ 1,688 was case only
$ 600 for vertical shaft ( apparently, they use
a 2" short sportsmaster shaft)
lead time was 4 weeks.
Nauti By Nature 02-10-2006 04:24 AM
i'M LIKE TO KNOW IF THE BRAVO SHOP LOWERS WITH XR UPPERS WILL HOLD UP ON MY 38 FEVER WITH 650 BLOWER MOTORS .
THOSE B*MAX DRIVES LOOK QUITE SOLID THOUGH !
RATED AT 850HP USAGE , ANYONE USING THEM ?
WOULD LIKE FEEDBACK THANK YOU .
Ran-Dom 32 02-10-2006 07:57 AM
depending on what kind of a driver you are, I don't think you will have a problem with that set up.
Nauti By Nature 02-11-2006 10:07 PM
offshore conditions in NY NJ long island areas sometimes demand more from equipment , if the driver is up to it !
so when I am ready the equipment needs to be ready also ,
as ready as the driver I might be running against , to avoid mechanical breakdown .
Strip Poker 388 02-12-2006 01:56 PM
2 Attachment(s)
B Max
Nauti By Nature 02-15-2006 10:26 PM
Originally Posted by Strip Poker 388
B Max
Are those lowers built with xr gears ? and hardened steel
prop shaft?
Is there a updated version of the lowers coming out in near future ?
Marginmn 02-15-2006 10:43 PM
B Max
That B-max on the right looks sharp.
