Anchor Storage...?
I have a 1991 27' Fountain Fever and no where to put my anchor....!!! Where does everyone put them...?
Re: Anchor Storage...?
I have a folding 35lbs anchor for my 27 and I put it under the hatch there is a small step that opens it fits in there sidways :evilb:
Under the rear seat. welcome to owning a Fountain. You can get there fast and in style, just can't take nuttin wit ya. :D
i have an alluminum danforth type that i put under my rear seat
under the rear seat......BZ
does anyone make a bracket or anything that could be mounted in the engine compartment...? If I put it under the rear seat I will have no where for the life jackets.....
My previous boat had a laundry basket (I think) held in place with a couple of peices of rope next to the motor. I used it for the bumpers mainly, but will work for anything.
Any type of basket would do the trick West Marine carries straps that clamp over the bow railing of cruisers to hold anchors. Those will work too. May take a bit of modifying to screw them to your bulkhead. Just a thought. For that matter. just a couple of hooks from your local hardware store to hold the anchor upside down by the bar. If you have a fluke type anchor. |
can anyone post a pic of an anchor that will fit under the rear seat?
I would put mine in a nylon bag with the chain and rope and put it in the engine compartmet secured down so it would not move. I'll look for a pic.
Fortress makes an aluminum one that breaks down in a bag that fits under rear seat.
buy a bigger boat or always raft off of someone else :D
problem solved :evilb: sorry had to be an a$$ |
I bought my Fountain used and it has a bracket that is mounted in the engine compartment. I will try to get a pic for you tomorrow.
1 Attachment(s)
Here's the pic.
I cut about 1.5" off each end of my anchor, just enough so it will fit under the seat.......I know the extra length of that top bar helps stabilize the anchor so it will set properly but it works fine and I anchor quite a bit...........doug
2 Attachment(s)
Here are my pics.
I did the same thing, cut off the rods flush with the flukes to fit in the rear seat.. I never understood what good the extra 3" or so per side the rod did. Never been a problem so far. |
| All times are GMT -5. The time now is 02:11 PM. |
