-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Performance Question on a 35 (https://www.offshoreonly.com/forums/fountain/126575-performance-question-35-a.html)
mardonzi 04-03-2006 05:28 PM
I recently bought a 35 Lightning.. and have some questions/ concerns on the performance.
I ran it for the first time this past weekend and some of the performance stats seem off to me.
It has 600 SC's, running 28 pitch props. At 4500 RPM's the gauges say that I'm generating 8.5 lbs of boost. This seems way high to me (even running at 4000 ft elevation).
Anyone have any input on this?
mardonzi 04-03-2006 05:37 PM
Re: Performance Question on a 35
Here's what the guages were reading.....
http://www.hotboat.com/image_center/...35HPIM0837.JPG
louietherigger 04-03-2006 09:06 PM
what was your fuel pressure reading? oil pressure looks a little low for that rpm also, your boat should run in the mid to high 80's and turn up at least 5200 if rev limited.altitude can wreak havoc on your fuel needs and boost was your boat built locally?
GOODT 04-03-2006 09:21 PM
your boat/ engine combo you should be turning mid to high 90s if not better at 5200 rpms
Fanatic 04-04-2006 01:55 AM
600sc in a 35 you should be in the high 90's maybe 100. What year is the boat and single or twin step?
RaggedEdge 04-04-2006 05:14 AM
Check out the pic. Single step boat. Newer twin step has curved glass windshield. My guess --- mid/late '90s. Speed likely mid 90's, unless they have been tweeked, which may be the case. I believe boost as stock from Merc would only be 5 -5 1/2 lbs.
Downtown42 04-04-2006 07:50 AM
Boat is 1995.
jryan26 04-04-2006 07:57 AM
Is that the top speed right now? 80 @ 4500?
jryan26 04-04-2006 08:21 AM
1 Attachment(s)
Looks good. Any more pictures?
mardonzi 04-04-2006 08:48 AM
Boat was just spooling up in that pic. Still hadn't tweaked the trim. The boost has me worried (8.5 lbs). The fuel pressure was running about 4.5 there.
I'm concerned about the Oil pressure as well. Should be running up in the 50-60 psi range, not 45.
The boat was supposedly built and run for Lake Powell, which is where the pics were taken.
