-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   33 Fountain Prop Question (https://www.offshoreonly.com/forums/fountain/126625-33-fountain-prop-question.html)
SeaWeasel 04-04-2006 11:06 AM
1990 33 Fountain, 454 Mags. Currently running 25P 3 blades. Anyone have experience with this set up? Boat will run in the upper 60's WFO at 4900 rpm with a light fuel load, trimmed out level tabs. Would like to try 4-blade. Thoughts? Suggestions? Anyone? :drink:
Lofty 04-05-2006 04:38 PM
Re: 33 Fountain Prop Question
Non-Steps have a hard time getting enough bow lifty with a 4 blade. Those motors should be turning 5300 at WOT but your speed sounds about right for your set up. 4 Blades will look good on the trailer but in the long run your probably better off with what you've got.
barron 04-05-2006 04:47 PM
I would try 22 Bravo 1 . That should help mid range but might take a little off top end .Good luck.
SeaWeasel 04-05-2006 04:58 PM
Thanks for the help- I have a set of 24P Hydro Quad IV's on my Formula we are going to try on the Fountain. :evilb:
pachangalpina 04-06-2006 07:50 AM
My non step 38 likes the Mirage and 4 blade Bravo1 props better than the Hydro. The best speeds have been with the Mirage and the Hydro seemed to give too much stern lift.
