Re: engine puked!
Originally Posted by 99fever27
I was towed back to the marina by a nice guy in a Bayliner. :eek:
THAT has to be embarresing, did you hide in the cabin???? check filters, timming then things get tougher but start there as stated already temp was ok? |
Re: engine puked!
Coil?
Re: engine puked!
[QUOTE=GOODT]THAT has to be embarresing, did you hide in the cabin????
Embarresing doesnt describe how I felt. After flying up and down the lake and probably pizzing everyone off, I was happy to see anyone come by to offer a tow. Nice guy though, wouldn't except any money. I didn't hide in the cabin but I assure you I was out of beer by the time we made it to my marina. I'm going to do a complete service on the engine this weekend and start checking everything out with the little things first. Coil isnt one I thought of but the way it was cutting out it makes sense. |
Re: engine puked!
Originally Posted by 88Fountain
If your Matt, then it's me Aaron. We had a great time in Richmond. How have you been? It sure has been great weather for boating lately. We took our boat down to SML a couple of weeks ago. We'll have to hook up with you at the lake or on the river.
Re: engine puked!
Hey Aaron yep thats me. Had a great time also..im surprised we actually won that pool game being so drunk! :D We should hook up on the water this summer, are you going to do the poker run on SMl or the Potomac?
Re: engine puked!
When this happened to me, it was the ignition switch. Give the key a jiggle and see of it cuts out. Hope it is something simple!
Re: engine puked!
The distributor should be tight. If it is lose I would definately reset your timing. Might want to check your fuel water seperator, is it possible you got bad gas, maybe has water in it.
Re: engine puked!
I hate to hear about this stuff so early in the season. I hope it is a simple fix for you and it doesn’t keep you out of the water to long.
Re: engine puked!
Ethanol in the fuel?
Just got done reading the threads about ethanol. If you got stuck with some fuel that was tainted with ethanol, you might have gummed up the carbs / fuel filters. |
Re: engine puked!
First take a fuel sample, then verify whether or not you have good "spark", and timing. Then, if these are good, check compression. Check for the necessities. When you find a problem with one of these systems, then you can focus on repairing the problem. Start with the easiest to check and work to the hardest.
| All times are GMT -5. The time now is 09:44 PM. |
