-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Help!!!!! Boat Wont Plane!!!!!!!!! (https://www.offshoreonly.com/forums/fountain/131215-help-boat-wont-plane.html)
candyman35 06-20-2006 10:43 AM
Re: Help!!!!! Boat Wont Plane!!!!!!!!!
Originally Posted by carney
Is it possible that you have one drive cable in forward and one in reverse, One cable goes on top and one on the bottom of the assembly ?????????. and or check fuel pressure.
Was thinking the same thing.
The Throttle cables go on the furthest back hole on my '97. I would do as Birdog said. He knows his Fountains! :evilb: :drink:
Dan
RaggedEdge 06-20-2006 12:13 PM
One foreward, one reverse, boat would rotate as when docking.
carney 06-22-2006 06:55 AM
But if both drives are in forward the reverse rotaion prop will be turning back wards. , Am I thinking right .
sleeper_dave 06-22-2006 08:35 AM
I've noticed that my boat planes better with the drive at 3 or 4 than it does with the drive all the way in. The prop starts to ventilate a little, the revs come up, the power comes on, and bam, it's on plane. If i trim it all the way in it just lugs along at 2500 rpm until it drags itself on plane.
FOUNTAINATLAST 06-22-2006 10:46 AM
Interesting what size is your boat, May be something new to try. You still using your tabs???
blownincome 06-23-2006 05:36 AM
Do you have MPI/or 496 Motors If so they may be in Protection/limp mode?? You would need a rinda tool to Diag..if so clear the fault code and your Off
My .02
itilldo 06-23-2006 02:39 PM
I saw the post and I thought that it was related to Speed Racer :D :p
tomtbone1993 06-23-2006 05:19 PM
it sounds to me like a electrical / safety issue with the motors, I don't think it is wired correctly
