-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   water in bilge (https://www.offshoreonly.com/forums/fountain/131315-water-bilge.html)
sonic28 05-29-2006 06:49 PM
water in bilge
new 2004 fountain 35 ex no leaks that i can tell.all hose clamps tight.is it possible for the water to enter the bilge thru the bilge pump outlet fittings.they are very close to the water line.is anyone else having this problem?
Downtown42 05-29-2006 09:42 PM
Re: water in bilge
Yes my 35 sometimes water will get in there at beach's. Water splash can get in the vents too.
Jnewton 06-03-2006 12:35 PM
Re: water in bilge
My 42 Lightning was taking in a small amount of water for some time and I couldn't figure it out. Finally I had occasion to mess with one of the big stainless exhaust pipes going out through the transom and found that it wasn't sealed where it passed through the plastic bushing. There is supposed to be silicone around the pipe, but two of mine had nothing, therefor the slow leak. I suggest sealing all 4 (I used black high temp silicone) and giving it a try.
It was undetectable from inside the bilge, but at the end of the day I had water.
Hope this helps.
Hot to Go
Need-the-Speed 06-04-2006 12:24 AM
Re: water in bilge
My Exhaust lets a little water in from the Hinge pin housing which the internal flappers are conected to. These are the ones that control the direction of the exhaust -out throught the hub or our through the transom.
Fountainclimber 06-04-2006 07:06 AM
Re: water in bilge
There was an other thread about this not too long ago. Don't forget to check if your cooler emptys into the bilge. Mine also leaks at the silent choice diverters.
F
sonic28 06-05-2006 08:02 AM
Re: water in bilge
thanks guys but none of the above.i tasted the water it's salt so i know its not the cooler.i might try that jello thing next!
UNSANE 06-05-2006 08:36 AM
Re: water in bilge
I always get water in there, for me it's coming from the big vent holes out the back. I try to bring it off plane as slow as possible to keep water from sneaking in, but I still get some, I can see it by the tubing for the blowers.
pachangalpina 06-05-2006 09:36 AM
Re: water in bilge
How many hours are on the motors? Check the engine circulating pumps and see if they are dripping from the weep hole from the underside of the housing. Also is stated earlier, it could be the blower vents taking on water as you are coming off plane.
sonic28 06-06-2006 09:42 AM
Re: water in bilge
not the blower vents.the boat has 4 hours yes four hours.
Deltarat 06-06-2006 09:51 AM
Re: water in bilge
I had a leak in my boat when I bought it, it tured out to be the rubber boot the shift cables goes through the drive in had a small tear in it.
