Toe In / Toe Out ?????
Need some info regarding toe in / toe out setting for the drives on the boat. Called Fountain today but kept missing the person I needed to talk to about this. Would like to check the setting before launching.
1999 35 Fountain Lightning Standard Bravos at regular factory X dimension Props are turning in Would like to know in or out, and how much. Thanks in advance ! |
Re: Toe In / Toe Out ?????
I've always been told that the bullets should be towed in 1/16th to 1/32nd.
Robert, If you happen to be around LCM the next day or so could you ask them about the toe setting ? Appreciate it !
I called the Fountain factory once about 4ys ago......I cant remember who I was talking to but he yelled across the shop to a couple of different guys and they went back and forth for awhile and the consensus was "dead ahead.....perfectly straight"......thats what they said......doug
Well finally got thru to Fountain today, and the answer is 1/16 Toe In on the 35. Ran this past weekend at 3/16's toed in and the boat feels good but may be off about 100 RPM, hard to tell that small a difference. Will change it this week and go again.
How do you measue this?
Did you ever see any more speed with the toe in?
toe in
under 90 1 / 16 over 90 1 / 8 |
| All times are GMT -5. The time now is 06:22 AM. |
