-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   00 35 anchor (https://www.offshoreonly.com/forums/fountain/134255-00-35-anchor.html)
JMPH 07-03-2006 07:52 AM
00 35 anchor
can someone with 00/01 35 Lightning please send picture of anchor in anchor locker. I must have wrong anchor because there is no way I can clip mine into bracket from factory
thks Joe
johnnywhip 07-05-2006 09:33 PM
Re: 00 35 anchor
Same here Joe...previous owner lost the anchor :( ...anchor locker looks real cool with brackets... but what size/brand anchor for 35?? whip
Beak Boater 07-06-2006 09:08 PM
Re: 00 35 anchor
I dont have a picture, had a 35 with a anchor locker. The anchor stands straight up and the bracket with the pin throught it holds the beam of the anchor. If its the original anchor, it will have a hole drilled that matches the pin in the bracket.....Fountain makes their own anchor so it will fit in the locker standing up with the flukes pointed upward. The anchor wouldnt hold worth a damn. Had 4 foot of chain, plenty of rope wouldnt hook unless it was flat calm. I have the same anchor in my 38 Lightning, same problem, I cut down a Fortress and fit it in the locker. Hooks everytime. If you really need a picture, I can take one of the 38, this weekend.
itilldo 07-06-2006 09:25 PM
Re: 00 35 anchor
Please post a pic for us mentally challenged :D
johnnywhip 07-06-2006 11:10 PM
Re: 00 35 anchor
Pic pleeeze...and is the Fortress alum, gal steel, or? thanks, whip
gferdon 07-07-2006 06:48 AM
Re: 00 35 anchor
I used a Fortress aluminum anchor in my '04 29 anchor locker with 150' of rode and 5' of chain. I had to cut the bar at the fluke end about 4" but it did not seem to make a difference in holding power. My strong suggestion is that you abandon the anchor locker...my rode was always wet and snotty (not to mention moldy) and generally hard to work with. My new 35 EX does not have an anchor locker. I purchased the Hydro Bubble 3500 kit, the whole deal weighs less than 20#, comes in a great little bag and fits under the rear seat. It's always dry, neat and ready to go! Your choice...my .02! Best of luck. BTW the Hydro Bubble works better than any other anchor I have ever used!
Here's some info: http://www.anchorconcepts.com/html/welcome.asp
Gary
Beak Boater 07-07-2006 09:16 PM
Re: 00 35 anchor
I will take one on Sat. and post it. Fortress is Alum. or some alloy of Alum.
