35' Fountain
Anyone go from staight bottom to a step bottom. Any diff. in ride ?I know step bottom rides fairly flat not needing much trim,but how do both compare in ride i n rough water.Thanks
Re: 35' Fountain
night and day difference!
Re: 35' Fountain
Re: 35' Fountain
night and day is right!!
had 93 non step 35 went to 2002 twins step,, no comparison,, super efficient hull on the 02 runs flat requires much less trim, rides nice and flat in the rough, 93 35 550hp per side 80 - 83 mph 02 35 stock 575's are about 550 hp = 90 +++ |
Re: 35' Fountain
Re: 35' Fountain
Originally Posted by barron
I know it runs flatter [ STEP BOTTOM ] but would you say as far as comfort are they about the same in rough water ? I'm in fact looking at a 93 boat not to concerned with top speed as much as the ride.
i loved both boats,, have you ran a boat like this at speed? if not the reality is when it gets rough and you can still carry speed and keep it trimmed in and runnin flat you dont get pounded, same water same conditions i would be able to run the newer boat a bit faster and keep drives trimed out a tad and tabs down a tad and would rip over the top,, old boat had more of a tendency to pop bow up and drop stern in the next hole, i would have to run it with more trim to keep speed and then tab down to keep it from flyin nutty,, :drink: just my o2 i am not an expert just my observations,,, :eek: |
Re: 35' Fountain
The step will allow you to run fater and flatter thus making the ride more comfortable in this boat. In really big rough water there would be no difference but in a chop then yes.
Re: 35' Fountain
Thanks to all, and I hope not to be disappointed but I think the 93 will better fit the budget better.Unless someone know of an early single step out there at good price. Thanks ! :D
Re: 35' Fountain
I had a 93 and loved it. The original owner bought it back from me cause he missed it.
http://i13.photobucket.com/albums/a2...own42/35DT.jpg |
Re: 35' Fountain
Thanks, just pulled the trigger on the 1993 boat.Boat will be checked out next week.
Re: 35' Fountain
PM OSO member "tanner" Todd has a 35' Fountain, 1996 I believe. Motors and drives were done in 2004, he'd like to sell it.
Re: 35' Fountain
Barron, If your 1993 does not check out , as Lucky Strike said I hae a 1995 single step hull, engines are stock 502's replaced in 2004, and drives. I am looking to sell it. If you are interested I will give you all the up to date items on the boat, new dash, guages, controls interior,stereo etc..
Good luck with your shopping Todd |
| All times are GMT -5. The time now is 06:42 PM. |
