Question on props for the fountain guys
what pitch are you guys in the 32-35 ft range running on your boat. I am looking to get a set of props that will give me a nice cruise and top end, rather then out of the hole, also power in the boat will be in the 600 hp range, per engine.. Thanks with any info on this.. JOHN
Re: Question on props for the fountain guys
I'm turning 26" Hydros in a '32 with stock 415hp 502's. Just as a refernce. Looks like you should be able to step that up with 600hp.
I have a 1998 32' Fever w/ 502/415's but it has Gil headers and risers which probably adds a little bit more HP. The ratio is 1.5:1 and I run lab finished Bravo 30 pitch turning out. The last time out on a cool day we ran 82 mph on the gps. I would think you could run at least 32 Bravo's with 600 HP. My buddy has a 2004 35' Lightning w/525's also with 1.5:1 ratio and he runs Bravo 32's turning out and he runs 91 mph on the gps. Have you considered 5 or 6 blades?
Good gawd, 82 on 415's.
I tried a set of 28 Bravos and was lucky to turn 4500. My best with my 26 Hydros that have been blueprinted is right at 75mph. I'm running SM exhaust. I gotta dig deep into my motors and see why I got the slow ones. |
Originally Posted by 35 fountain
props are trial and error - but with 600 horsepower and assuming a 1.5:1 ratio I would start out with a pair of 30 pitch Bravo 1s. If you are pulling all the way up to your desired RPM you can determine wheather you want to go longer on the pitch with a lab finished prop. If you are a few hundred RPM shy then you may want to drop back to a 28. I have the same quandry with an 04 35X - boat runs 80MPH with 496s on 1.65:1 but I would like more in the midrange than my stock 32 pitch bravo 1s are giving me and its not like I can afford to make mistakes buying propellors. All I can say is see if you can borrow someones set before you buy. Where is Northpoint Creek? I am running out of Pasadena and am looking for another Fountain to run with.
Where you keep your boat at, rock, stoney, mag, bodk.. I am strait across from Rock creek..Also a friend of mine and dads has a 35 with a set of pro chared big blocks that runs out of here also. Hey man i don't have a prob, if ya want to get togather sometime, if yah don't mind hanging out with a 24yo :drink: also my dad too, but we like to have a good time brotha.. :evilb: Again thanks fellas JOHN |
35 FOUNTAIN
Much higher x dimension on the newer fountains. I prefer the handling of the hydromotives to the mercs. they are faster on the topend.ifyoure running stock 1.5 Bravos I would start at a 27p Hydromotive 4 blade and work your way up. Before you go buying expensive props in the 30-32p range. I ran 26 hydros on my 32 with 425hp. I would think that a 27 would get the job done. start there. 27,28,29p props are easier to get rid of if you make a mistake. I don't think with that set up especially if you are running stocklowers that you are going to pull a 30 anything.
I run a 32 fever with joey griffen 650's....30P Labbed Bravo 1's turning in. Going to play with some new props in the spring so I might have the current set for sale (if you can wait that long!) Have fun
another ?? is what is everybody running the bravo's for, not trying to be a smart ass just curious.. Thanks JOHN |
Actually, mine are bravo cases with Imco innerds and Imco shorty lowers...dont know if that helps but so far they are bullet proof!
are the bravos better than the hydromotives? I'm turning 26 hydro's on a 32 with 502's. GPS 78
I have both for my 35, 28 Lab Bravos and 26 Non-lab Hydros. Both sets run very close to the same speeds. The Bravos are better in terms of general boating, they plane at a lower RPM and have a higher cruise speed due to more blade area. The Hydros work ok overall, give up a little in the cruise range, but on the high end I prefer them, the boat needs less trim and runs flatter at the same top end speed. I just like the way they "feel" better, the boat doesn't move around as much, especially in rougher water. On a good day they might be 1 MPH faster, very little difference. |
I also like the Hydromotives over the Bravos. I've never tried a labbed Bravo, but I did try a stock Bravo. It seemed that I lost some on top with the Bravos and didn't "feel" the same. I've heard that a labbed Bravo makes a world of difference. I have to make a decision next year also, as I was borrowing a set of hydromotives. I wonder if the hydromotives will work the same if I used shorties?
Fountains usually like the 4 Blade Hydromotives for top end. They will not get on plane like a B1, in the midrange they slip more than a B1. I have been told that a Lab finished B1 is as fast as a Hydromotive on the top end. Dont know that to be absolute fact. I run Maximus 5 blades on a 38 Fountain.
Are the Maximus' worth the money?
My set up with Bravo shorties makes it nessasary to run 5 blades. Again it is what you are looking for. If you are running standard length drives, the Maximus will be slower on the top end, but will not slip as much in the mid-range so you would pick up mph their.
| All times are GMT -5. The time now is 09:00 AM. |
