Drive Question
I've got a 1996 27' Fever Step bottom, with a built 502, B&M Megablower, pushing around 800hp.
I had a regular bravo drive, it lasted a summer, now its losing oil. Any suggestions on what kind of drive I need to get? It is worth having the old one rebuilt? It was suggested that I get a shorty, but the mechanic doing the work says that with that power and with me pushing 90 I will spend most of the time out of the water on ruff days. I also am way under propped. I've got a 28 labbed - cruising speed at 3000 is about 45. Any advice would be greatly appreciated. Thanks |
Re: Drive Question
spend the money and get a drive that can handle the hp it will be worth it in the long run
Re: Drive Question
What do you suggest? XR?
Re: Drive Question
Originally Posted by apppedigree
(Post 1981004)
Re: Drive Question
imco extreme
Re: Drive Question
I would have your old drive disasembled to see what is wrong. If its minor just fix. If you need a gear set change to 1:36 . Even with your horsepower its big props that blow drives.
Re: Drive Question
I ran a 30 - 5 blade for a weekend at SML Labor Day. I could tell it was too much.
I would really like to go with a good IMCO extreme rebuilt - test some props and see what it does. I was told a shortie would help, but I am worried that I will spend more time in the air than in the water. |
Re: Drive Question
Going to a shorty is 2" higher. If its in the air so is a bravo.Don't be afraid to try a high 5 or Rev 23 prop. A Rev 23 will give you the performance of a bravo 30.
Re: Drive Question
I also have a 96 27' with a Stg. II Procharger making around 750 hp that runs 90 on gps and have tested a Imco 2" shorty and at least a dozen props in the last five years, if you would like to discuss my setup just let me know, I am more than happy to share info! By the way, if anyone you know is in the market for mint 27 that has been meticulously cared for let me know, I recently bought a 35 so it needs a new home.
Re: Drive Question
INDY27 - I would love to discuss your setup.
Let's get up. I'm going to take a few pics of the drive on the boat now. Thanks for the help. Shoot me an e-mail " [email protected] |
| All times are GMT -5. The time now is 04:47 AM. |
