Diamond plate engine comp.
Any body ever do there engine comp floors in alum diamond plate, I'm thinkin of it ,easer to stand and work on. Any body got any pic's with this done to boat .Anything would be a help. THANKS JOHN
Re: Diamond plate engine comp.
3 Attachment(s)
i am not done but my mag is going to blind ya next year
Originally Posted by nocigarette
(Post 1990579)
1 Attachment(s)
Heres what I did on our 42....The squared corners are now 45'd
Originally Posted by 35 fountain
(Post 1990693)
very nice - you do this for a living?
No Cig and B4M - is your diamond plate removable so you could clean behind it or retrive something you dropped etc...???
yes mine is,,,,i put a two way foam tape on the back and used stainless screws in other areas...........Mine covers my fuel tanks and most of my rigging .....You have to make sure you get a good fit and secure it properly because it will rattle
(Post 1991883)
just a dab of silicone on the scews................A local sheetmetal shop can due all the bending for ya......Try to break the sheets as much as possible.......with gaps or trying to butt the sheets together looks like crap......Looks a lot better if it is bent or rolled, most shops have a ten foot break so long pieces should not be a problem
Yes, I have (8) 1/4 lock screws holding it down.
| All times are GMT -5. The time now is 03:45 PM. |
