-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   What boat lift for your fountain? (https://www.offshoreonly.com/forums/fountain/151483-what-boat-lift-your-fountain.html)
FeverMike 02-17-2007 09:29 AM
The important thing is to make sure the bunks go past the transom and to have the bunks cut to support the step hull properly...THIS IS VERY IMPORTANT!
US1 Fountain 02-17-2007 04:59 PM
I agree. I just can't get over how many lifts I see that have a couple short bunks in the rear, then a simple Vee bunk up front. Not to mention half the boat length hanging over the front Vee. There has got to be a lot of pressure on that point. Mainly on the larger boat lifts, 42' or so and up.
tblrklakemo 02-18-2007 07:32 PM
Just purchased an 8k lbs poly lift for the 27. The lift is two years old and is from the prior owner of the boat....fit for the boat. The manuf. is going to un-install, transport, and re-install for $800....sound reasonable?
epeek 04-03-2007 05:24 PM
Originally Posted by Jeffro111 (Post 2080061)
I just sold a guy a Sunstream 12k lift on lake superior for his fountain and he loves it
I just bought a 12k Sunstream for my 35. Do I have
to do anything with the bunks for my stepped hull?
tblrklakemo 04-03-2007 06:47 PM
Just make sure they support the boat before and after the step and extend past the transom a couple inches. Obviously the bink will be a little higher in the back to hold the hull behind the step.
On Time 04-04-2007 10:14 AM
Called Fountain Customer Service and they faxed me the engineering drawing with precise measurements for a custom cradle to fit the stepped hull exactly. My boat lift guy made it for me from treated wood and galvanized metal for $2000 and it works perfect. I use a remote to raise it out of the water when I am out for the day. :)
Bad Girl 04-08-2007 11:56 AM
need a hoist?
i have a 12k in ohio. its in the swap shop.
ripride1 04-11-2007 11:31 PM
need a hoist?
What are the details on your lift. I found a 16K that will be perfect for my buddy but to big for me. I have my 35 on an 8K and I need to completely refab the bunks for the twin step or preferably upgrade. You can reach me at 518 441-5379.
Thanks Dan
carney 04-15-2007 09:28 AM
2 Attachment(s)
This is what we have for a lift.
