24 CS prop help
Just traded in a super clean 95 with 454 Magnum carb. Has the original 4 blade Mach 26" prop. Way overproped,got to do a little prop testing. Does this boat need a 4 blade as I have several 4 blade Bravo 1's to try? What about a Mirage 3 blade? Suggestions?
I had a 24ft baja with that much power and ran a 24p mirage +. I think a four blade could have helped get it out of the hole a bit better, but It sure did run good up top with that 3 blade.
Try a 22 Bravo 1 but I thin a 24 Bravo 1 might work well too.
I'm running a 4 blade hydromotive 26 pitch 502mpi on my 97 24cs. tacks about 48-4900 rpms. 72-73 mph. Intimator 4 prop.
