What to use on the plexiglass windshield
A little while ago I asked for every ones advise on what to use on the plexiglass windshields and got a lot of responses on what you were having success with. I happened to be talking with Fountain's customer service line today and asked them what they recommended - they told me to use "210 Plus" which is a plexiglass scratch remover and "210" which is a cleaner and polish. I did an MSN search on the stuff and found a distributor in Dayton Ohion called Spinners which is a pilot supply store. The number is 888 305 7746. I ordered some of each and I'll let you guys know how it works out.
ok thanks.
Is it applied by hand, or do you motor it in? Will it affect the tint?
I think you could do it either way but I'll try it by hand first. Since Fountain recommended the stuff I dont think it will have any adverse effects, say like on the tint. My windshield is in excellent shape but I have some minor abrasion from the cockpit cover on the left and right corners and I think it will help with this.
Originally Posted by 35 fountain
(Post 2084638)
I hope the cleaner does not cost much. I was reading my hp manual and merc said to use 730 dow corning sealer on my blower gasket. I tracked it down , ordered a 3oz tube. Drove to pick it up and it cost 80.00. it had better be worth it. we have had some problems with our fountain windshields spider cracking, you can not see out of them.???????
Originally Posted by carney
(Post 2093837)
Very common problem. Side panels seems to be the worst. Have heard many explanations: cleaners with amonia (Windex), excess heat buildup from when cockpit cover is on, to nature of the beast. When I bought my boat, it was 3 yrs old and the side panels looked like somene took sand paper to them. I replaced them with new and only use boat soap and water on them and only use chamios to dry, no towels. 4 yrs later, they still look new with no scratches or the dreaded crazing. The windshield it self is fine, but has a few crazing cracks right at the bend at the deflector. Not sure why the side panels are more prone than the W/S as they are the same material. Maybe the heat applied to the W/S when doing the bending of both the arching and the deflecter anneals (relieves) any built up internal stresses within the material itself??? A few yrs ago a buddy took a heat gun and light went over his side panels and the cracks seemed to have become almost nonvisable. Last about a yr, then he reheats for another yr. My original side panel. Odd how the problem is more evident to the area not covered by the corner trim peices. Cleaner??? |
(Post 2093837)
| All times are GMT -5. The time now is 12:09 AM. |
