-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Fountain Factory Mufflers (https://www.offshoreonly.com/forums/fountain/161903-fountain-factory-mufflers.html)
GCAT911 06-26-2007 09:36 AM
My 35 Has The Factory Mufflers, Obviously At Times
I Miss The Loud Rumble Of The Engines. However On
The Other Hand I Can Pull Up To Water Side Resturants And Not Get The Hairy Eyeball Either.
Performance Loss Is Undetectable And You Can
Carry On A Conversation While Running At Nominal
Speeds. Anybody Else Have A Comment?
tblrklakemo 06-26-2007 09:38 AM
Never seen one with them.....i would rather keep my corsa silent choice. But, you are probably runnin less weight. Minus the y-pipes and all.
Oh, and its "lightning"......w/o the "e"
techman 06-26-2007 10:48 AM
I have them and they are nice units. I like that they are mounted flush with the rear of the swim platform for a real clean look. It also makes it easy to see water flow out the rear of the boat. It makes a cool spitting effect when off plane. If someone gets too close to the transom with the boat at idle they get a bath!
They are actually fairly loud but take away that raw bark that you get with a completely uncorked system. People can hear me coming but you don't get that noise fatique at no-wake speeds.
The system still uses a y-pipe by the way. I'm sure that helps divert some of the back pressure at certain RPM's.
