trim limit
2004 35 ex can you adjust the trim limit switch to bring the drives higher out. when up to the lake i like to beach it but can't do to the drives are to low.my last boat had a trailer lift switch this does not.
If you have XR Drives & HP Transom assemblies - I don't think there is an adjustment. Mine come all the way up with the switch in the throttle stick. I'm assuming you have Trim indicator cables - not gauges.
My XR doesn't come up too much either, but it's mounted so high up that it's still above the bottom of the hull. As far as sucking up sand goes, I have a strainer. I don't worry about that too much.
bravo ones.I am not worried about the sand but the drives are sitting in the sand and cant move the boat.
| All times are GMT -5. The time now is 10:46 AM. |
