-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   35EX Deadrise? (https://www.offshoreonly.com/forums/fountain/163710-35ex-deadrise.html)
Showdown 07-17-2007 10:29 AM
35EX Deadrise?
Can anyone tell me the deadrise on a 2005 35 EX? Looking to move up and want to make sure I get something with a good ride. Boating is done in LOTO and Tablerock Lake.
bsirk 07-17-2007 03:38 PM
I'm pretty sure all fountains are variable deadrise through the length of the hull. Variant between which degrees.......I'm not sure. :o
Sea-Dated 07-17-2007 03:45 PM
I think it is 24 degrees like most of the offshore boats. For LOTO I woul dget the biggest boat you can afford. It gets nasty out there.
tblrklakemo 07-17-2007 06:04 PM
Nope, fountains are 23 degrees at the transom. Not as steep as most offshore v's that have the standard 24 degrees. All the big sonics are 25 degrees. From a 25 baja to a 35 fountain you will not notice 1 degree at the transom.
Rebel_Heart 07-17-2007 11:18 PM
23 degrees is correct. Depending on where you boat at LOTO. I had a 27', but tired of coming back with a headache. The 35' would be minimum if you boat in the heavy traffic areas.
