-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   10 Meter planing question (https://www.offshoreonly.com/forums/fountain/164124-10-meter-planing-question.html)
10M 07-22-2007 12:48 PM
Hey guys, i have a question for you. I bought an '88 10 Meter in the fall, all stock (454s w/TRS). The dealer serviced it, all fluids are fresh and full. I noticed last week that if I hold it at about 2200RPM (i had to plane off very slowly in traffic) the RPMs on one engine climb rapidly with no speed increase. I let off right away, my 1st thought was that the tranny was slipping. I revved them up individually under load and it didn't slip, everything was normal. If I push the throttles to plane normally, (from idle to about 3000) no slippage. Once on plane i can give it all the power it has from any speed and it doesnt slip. Is something slipping or could this be some sort of cavitation? Drives were all the way in and the tabs about half way down.
MOBILEMERCMAN 07-22-2007 01:00 PM
At 2200 the boat is laboring to get on plane ,a lot of air is passing under the boat, the prop must have grabbed some air. The other tests you did revealed nothing I don't think its anything to worry about.
Jim
pullmytrigger 07-22-2007 05:53 PM
yep, sounds like your props are ventilating......let me guess.....three blade props??
10M 07-23-2007 12:24 PM
yup...That's what i figured, I just wanted to make sure there wasn't something i was overlooking. Thanks.
djtalon 07-25-2007 11:08 AM
do you usually have the starboard tab down further when you are cruising? Just wondering i have same boat and my starboard tab is always lower
Dkahnjob 07-25-2007 01:37 PM
Be very careful with reverse on the TRS transmissions. It is a weak point, so go easy with the throttle when in reverse. With careful treatment they will live a long time, but they are not super strong and they are hard to get parts for. The clutches are Ford-O-Matic parts and easy to get, but some of the gears are no longer available. I have had two boats with TRS drives. I love the way the hydraulic Merc Trans' shift.
Good luck and enjoy your new boat.
David
