-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   crack in cooler (https://www.offshoreonly.com/forums/fountain/164209-crack-cooler.html)
brians fever 07-23-2007 12:08 PM
crack in cooler
have a 2 in crack on the edge of my cooler incert called fountain they said it was 300$$$$$$$$ wowww. has anyone found on epoxy that will repair cracks before they break:mad:
sonic28 07-23-2007 12:45 PM
unscrew the the cover over the cooler disconnect the drain and pull the cooler out.no brainer grind the foam in the areas that are cracked and fiberglass from the rear.after thats done put the cooler back together and take a piece of rigid foam and place it under all four corners.this makes it rigid from bounce.how ever after I did it i purchased a softside cooler and leave it on the floor in the cockpit.no banging your head looking for a beer.
brians fever 07-24-2007 11:50 AM
thanks for the reply will go get some glass and resin and give it a try :party-smiley-048:
UNSANE 07-24-2007 02:58 PM
I completely wasted mine, therefore thanks to someone else here sending me pics of their setup, I put in an Igloo 25qt cooler. And I mean this thing is IN there. Way over-engineered!!!
brians fever 07-25-2007 11:35 AM
can you send a pic for future
UNSANE 07-26-2007 09:10 AM
I'll take some today and post this evening.
brians fever 07-27-2007 10:44 AM
glassed in the top 5 inches of the lip worked out great am going to re install the cooler today thanks for the tip
