No More water in the forward bilge
I Think I finally got things figured out on my 35 Lightning Classic, as far a water in the forward bilge. This has been an ongoing problem for me. Well the boat is now at Lake Havasu where it is always hot and the forward bilges finally dried out while the boat was on the trailer in storage in my garage.
I believe that the water was coming from the ice chest when I would pull the plug and let it drain while the boat was on the trailer. The boat sits bow low on the trailer, even if I have the tongue jacked up to the max. So on this trip I have been careful to only pull the plug in the built in ice chest when the boat is in the water and is sitting stern low (which it always is). That way the water drains to the rear bilge rather than the forward bilge. So far everything forward of the bulkhead at the step is dry. Dave |
I don't have a plug...I just throw ice in and when it melts its gone, day over.
I was getting water through the old screw holes from a previous rub rail. |
Originally Posted by Back4More
(Post 2247128)
I was getting water through the old screw holes from a previous rub rail. Dave |
water woes
i am having the same problem w/my 27fever.water is comming from the forward vent on the port side...i think.i do not thank it is rain water or cooler water.i dont use the cooler and the boat stays in a garage.ant food 4 thought guys?i have figured out how keep down the smell when i forget to drain the water out.condensate drain tabs used in the h/v a/c industry.non toxic,non corrosive.brad
Originally Posted by Dkahnjob
(Post 2247074)
Originally Posted by GCAT911
(Post 2251143)
Where is you ice chest located on your 35 classic?
(Post 2251897)
Ice chest is on the port side, toward the rear part of the cabin, built into the counter, I think most Fountains look about the same. The drain hose goes aft, through the bulkhead and drains to the area outboard of the stringers that go around the fuel tanks.
Louie |
Is there a way I could put a one-way valve on the limber holes in the engine bulkhead that would allow water to drain back, but not run forward when I put the boat on the trailer (or come off plane)?
| All times are GMT -5. The time now is 01:34 AM. |
