Gas stain
Any ideas on removing the gas stain from below the fuel vent on the back saddle tanks. The guy at the marina filled the rear saddle tanks instead of the front mains and the fuel expanded and leaked out the vent. Now there is a light yellowish stain below the vent. I tried Starbrite hull cleaner, but it did not take it all off.
i have had fair results with acetone
I mixed 3M rubbing compound with a little water went over area,then washed and waxed came out
Originally Posted by Expensive Date
(Post 2249849)
use the works toilet bowl cleaner try not to get on the trailer is it is on there ....and make sure u rinse it off the baot very well ......only works if the area u are trying to clean is dry
A light cut compound should do the trick, just about what they all said should work aswell.
JOHN |
Originally Posted by cosmic12
(Post 2249856)
:offtopic: what you doing in the Fountian fourms????:D
I've tried just about everything on my white rubrail from gas spills. Still have a stain. Any suggestions?
Originally Posted by Rebel_Heart
(Post 2250304)
| All times are GMT -5. The time now is 01:23 PM. |
