92 fever need help
I have just bought a 92 fever with a 525 hp merc. What prop should i run? Also im looking for the fuse panel the lights in the forward cabin dont come on.
I am guessing it is a 27 Fever, if so a 25 Hydromotive would be a good start, depending on your set up you could maybe go up to a 26 or 27, but would be a pain planning off.
Will:party-smiley-020: |
i have an 01 29 fever with about an equivalent to a 525 motor and have a 27 hydro QIV. i think a 27 B1 wuld be better though, it blows out sometimes, high slip #s and not enough rpms, about 5100. You can try my 27 if ya want it will be for sale if I can find a lefty 27 bravo.
You were right it is a 27' fever. Thanks for the help on the prop but i also need to know where the fuse panel is?
Is no fuse panel. Just breaker resets buttons under the rear bench seat.
Can't recall on my '94 '27, but my 32 has a cabin power switch at the helm that needs to be on to supply 12v power to the cabin. Have you checked for 12v to the toggle switch? |
| All times are GMT -5. The time now is 06:43 AM. |
