-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Another Water Pressure Question (https://www.offshoreonly.com/forums/fountain/167967-another-water-pressure-question.html)
monstaaa 09-07-2007 06:55 AM
Originally Posted by StrikinLightnin (Post 2262185)
Presently I believe the stainer has a 1/2" NPT female fitting on it which I use to run freshwater flush.I could replace with the popoff tied directly into the strainer and regulate pressure through the strainer.Simple enough..........
you could tee that 1/2 fitting, then use one port for the flush , and the other for the pop off.
StrikinLightnin 09-07-2007 07:36 AM
yep
that's what I'm gonna do
Thanks,
Dennis
monstaaa 09-07-2007 10:30 PM
go get em big D
