-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Fountain Bilge (https://www.offshoreonly.com/forums/fountain/169442-fountain-bilge.html)
fountain 47 sc 09-23-2007 06:58 PM
Fountain Bilge
I have a 47 Fountain and can't seem to get the bilge under the cabin clean. I have dumped gallons of water and bilge cleaner through the access rear of the head. The problem is the attitude of the boat in the water or on the trailer does not allow the cleaner to run into the bilge at the bow. Does anyone know a way of directly accessing the forward bilge to clean it effectively?
RJ1340 10-20-2007 11:49 PM
When you find out, let me know.
pookie 11-04-2007 02:41 PM
I just pulled the carpeting up in the center of the cabin of my 47 Fountain and cut a small access hole in the floor. The fiberglass is laminated to thin plywood which was wet and warped. I will replace it and reglass it but put an access door for the future. I have been trying for months to get an answer from Fountain about how to access water in the forward bilge to no avail. The limber holes were plugged with construction debris (from lousy quality control) and an access door would have solved the entire problem. I may have expected this from an entry level boat, but it is surprising to find in a Fountain after all the HYPE!
US1 Fountain 11-04-2007 06:17 PM
Don't look to hard. The more you look, the more pizzed off you'll get seeing all the crap left under the floor.
pookie 11-04-2007 09:37 PM
Maybe you can help since Fountain has been useless. There is a plywood beam under the floor down the keel which is wet and partially glassed. Is this a structural component? I hope not. That seems pretty cheesy. If so, how do I go about replacing it with something more waterproof?
pookie 11-05-2007 09:47 PM
I think I need a midget to climb in the bilge and replace the wet plywood from underneath the fiberglass. I wonder if Reggie is available?
don aronow 11-06-2007 09:39 PM
Good one!
Strip Poker 388 11-06-2007 10:20 PM
Is water getting in there or do you just want to clean it?
sleeper_dave 12-05-2007 03:44 PM
Depends on how you define "structural". Yes, it does add some strength to the hull, but If that's the only place that there's a problem, I wouldn't worry about it. You could remove that board and a few more and never have a problem with the hull.
That board on mine had a little moisture, but no rot. I asked my fiberglass guy what to do about repairing it, he said don't worry about it. He recommended letting it dry out over the winter and forgetting about it. He said that that board is there more as a support for the floor than anything else.
All of your stringers are plywood. It's not worth replacing them with anything, there's nothing that's truly waterproof.
Strip Poker 388 12-06-2007 12:27 AM
I remember a pick of the Yacht's Fountain boat that had a water intake in the center of the bottom were the stringer would be, About were the rear seat would be.
pookie 12-06-2007 08:37 AM
Thanks! That helps a lot with the decision. The fiberglass guy will be coming to look this winter. If it is a big ordeal to replace this, I'll just dry it out and reglass it, but this time, I'll glass over the top so it won't happen again.
sleeper_dave 12-10-2007 01:03 PM
I thought about that, but then if it gets wet, it won't dry out as easy. They can still get wet when fully glassed.
I was thinking of pouring a little resin in that area, until it starts to flow through the limber hole, to fill in the low spot that won't drain. Shouldn't take much, just have to make sure the hull is at the right angle when I do it.
