Battery Removal
I want to pull my batteries for winter storage. Will I be able to use the factory jumper cables with a battery pack to lower the hatch after the batts are pulled? Or do the batteries need to be in place to "complete the circuit"...so to speak?
2006 Lightning BTW. |
well its gonna be easy to test out....open the hatch...un-hook the batteries and try out your jumpers to try and close the hatch! you'll find out right quick if it works! :D
My jumper cables go directly to 1 of the batterys. If anything, you could simple bolt the cable ends together from both the jumper leads and the main power cables.
Originally Posted by techman
(Post 2292499)
Will I be able to use the factory jumper cables with a battery pack to lower the hatch after the batts are pulled? 2006 Lightning BTW.
Originally Posted by Downtown42
(Post 2292589)
yes.
So your jumper cables go to a switch instead of the battery then? |
You can use the jumper cables, but you need to "connect" the negative post wires (at the battery) together with a bolt/nut, otherwise ... nothing happens! Don't remember if you need to turn the switch on or not, but I do know you need to connect those wires together!
Uh, Take the bolt out of the ram and put a strap in. And It wont matter.
Just leave them in the boat, and give them a charge or two over the winter.
I won't be able to touch them during the winter layup if I leave them in. I guess no harm in giving them a full charge now and then see where we are in the spring. I wasn't sure how much I shorten their lifespan by leaving them in there during the winter freeze.
I tie the negative battery cables on the port side together with one of the battery box posts and then turn port battery switch to both. Works fine. (1997 35 Lightening)
Originally Posted by bob_t
(Post 2293302)
Get a battery jump pack and a wire with male conectors on both ends. Take the batterys out and put a bolt between the 2 black wires on the port side battery cables(completes the circuit) plug the jump pack into the 12 volt recepticle on your dash and you can raise or lower to your hearts content - piece of cake, forget the jumpers - they are a pain in the ass - this is just too easy
Originally Posted by fountain27ho496
(Post 2297472)
| All times are GMT -5. The time now is 01:50 AM. |
