Speed on a 1990 27 Fevever Twin 454
Anyone have one of these or had one ? Would be nice to know top speed.
2 Fresh 454 GM Crate motors..Not a lot done to them but fresh. Coned bravo out drives. Not much other performance parts other than steering and freshwater pumps. I am open to prop choice ideas to get the right set up ...Chad |
do you know what hp?......what props are on it now?
a lab finished 3 blade Mirage will probably give you the most all out top speed.....i wanna try some Merc Revolution 4s on mine this year though although they only go up to 25 pitch I think......supposed to give good bowlift which mine could use and supposed to give you a better cruise speed per given rpm......IMO i have too much wetted surface the way it is |
I had a 1990 with twin 365hp 454's. They had about 550 hours on it and were a little tired. Also, the props had some dings in them but I saw 70 once and 68 anytime I wanted to. The performance report that came with the boat showed a top speed of 77 but I doubt that was ever achieved after the one time Reggie drove it.
i`m running twin 350 small blocks, alphas, all stock on a 88 27 fever and i can run 67 hammered down
Originally Posted by mull
(Post 2428292)
that is on gps 67 i was running 3 blade 21p i just bought new drives that are counter rotate so i need to try some new props going to try 4 blade 21p to start
1 Attachment(s)
would that 67 be in salt?.........what are you reving?......im seeing like 5000 at 62 - 3.......got a counter rot. alpha for mine (f*ck it.....Im keeping them theyre cheap:D) along with some just built 360 hp smallies for this year........Im hoping for low 70s.......I know a lab finished Mirage will probably be the fastest prop but I want to try some Merc Rev 4s.......they,ve had some great succes in older straight bottom hulls with a deep x dim.......post some pics of your boat!.......heres the new engines
nice yeah i,m runnig in the chesapeakebay area mainly the choptank i,ve been told strong 350 motors will rock a 27 cause of the weight thank god for cheap alphas its getting a paint upgrade in march i,ll get some good pics
| All times are GMT -5. The time now is 10:32 AM. |
