Trimming your fountain?
When you are running at cruising speed, where do you have your boat trimmed with a average load? When doing speed runs (light weight) where do you have your boat trimmed to, tabs and drive?
I value life so when I am wide open I keep the tabs even with the bottom of the boat.
Originally Posted by Racerngr1
(Post 2556044)
Cruising speed - about 3. That is close to being level with the bottom.
Originally Posted by mcprodesign
(Post 2556062)
where you doing your speed runs? We did one on elsinore Sunday..Chad
When I'm running the boat, I typically trim the drive at about 3and the tabs not far off. |
i am closer to 4 but with boat out of water drop tab to even with boat use a straight edge if need be.go to fountain website the big reggie has a video and tells a little about it and how to extend your running area.
If I'm in the ocean or running an inlet, I put the tabs and drive at 3 (neutral). That way I'm ready for changing conditions. If the conditions warrant (good that is) I tend to pull the tabs up to around 2 (later 29's run a little faster that way) and start tapping my drive up. Cruising around 56 or so, my drive could be around 3.5, no higher than 4. I watch my GPS and try to maximize my speed vs. throttle input. This is for good water of course.
Rough water, different story. Drive is ALWAYS at neutral, maybe 1 tap up or down from there depending on the situation. Running into a sea, the deepest I've ever had the tabs is 4. (shouldn't be much deeper anyways). Running with a sea, tabs at 3 usually. What I'll do is see how the boat launches (29's fly pretty level) and adjust from there. I don't want the nose to go to far up or down. Furthermore, a speed increase will change things. 40 mph in my boat will beat you to death in 3 to 4's (even with good space) so I'll pick up the pace until she finds her "happy spot", which is usually around 60-65 for me. Being that you're in Cali, you'll get those 5-6 foot swells with 10 to 15 seconds between them. I've run that type of water before around 65-70 mph in my boat. In closer spaced water, I keep it around 60 or so as not to hurt the outdrive. Even though I'm throttling, you still get a quick "pop" out of the water here and there. Thankfully for me, I'm at 1/2 throttle at those speeds. Those "pops" tend to sneak up on you more in a following sea. Fountains are "drivers'" boats. Feel it out and you'll start to notice the little changes. Your boat has a different hull/setup than mine, so it will have it's own "happy place". These are just some basic guidelines to follow. |
Call Fountain and get the performance report, all settings will be listed at different speeds.
Originally Posted by Downtown42
(Post 2556543)
The best advise yet DT! Have Fountain send you the perf report and use it as a giude. I've been playing with my new one and what they put on the perf report is a real good baseline to work from. Reggie don't run them all anymore, but the guys he has doing this have it down. It is your best starting point, call the factory. |
I keep my drive at 3 or 3.5....level with bottom. My tabs are between 2 and 4 depending on water conditions. I dont feel any speed change with tabs up more than 2 (and dont like the wondering feeling at speed,) and below 4.5 they really begin to stuff the bow. When im attempting to get on plane i stuff the drive and put the tabs down considerably, and then begin to raise the tabs and then shortly there after the drive.....all based on attitude feel, boat weight, and engine RPMs. My max GPS (68.6) was with tabs at the 2.5 position and drive about 3 in very slight wind chop....if i remember correctly. Basically I like to keep the drive about level and use the tabs to make minor adjustments.
All of you guys seem to know what you are talking about, but it depends on what year 29 you have. Or is it a single or twins. My 29 cruises as you guys stated best around 3 on both drives and tabs. For top end I set the tabs at 3.3 (3.0 being level) and then run to top speed at about 5.6, then punch the tabs up to 3.0 where I have stops set. Boat runs 93 MPH. It is a 95 with twin 502s 575 HP. Later 29s have higher x-diminsion therefore not needing as much trim to obtain top speed. Rough water tabs at 3.5-4.0 and drives level at 3.0 level. I know everybody does this but I like to straight edge the trim and tabs and mark the indicators with a dot so you will always know where level is.
| All times are GMT -5. The time now is 09:13 PM. |
