Where's the rev limiter?
Anyone know where I can find the rev limiter? I have 3 wires goin into the distributor..Can I cut a wire?
http://members.cox.net/mcprodesign/Picture_030.jpg |
My '94 limiter was mounted inside the mount on rear of motor. item #43 Had to remove the module to get to it.
I don't think it's a simple as cutting a wire, may be wrong though. But when I ran my motor with the blower, I had a wire harness that I used that eliminated the rev limitor all together. It's a stock Merc item, but can't recall which motor it'd be on to order. http://www.mercruiserparts.com/Show_...2%2DF213244%29 |
Here's the harness that eliminates the rev limiter. Item 7a
http://www.mercruiserparts.com/Show_...L+AND+IGNITION |
Originally Posted by US1 Fountain
(Post 2561353)
Originally Posted by mcprodesign
(Post 2562073)
Thanks very much..
You're welcome!:D Your prop is on the way, and you have mail. I threw in the thrust washer and the rest of the chit you need to install it as well. Nice doing biz, good luck. Peter |
| All times are GMT -5. The time now is 04:01 AM. |
