Your motor is not making the 500hp, you should come up on plane with a 25 Hydro,
The 25 Hydro was standard on a 27 w 500efi in 2000 and 2001. You should not be having a problem unless your motor is not producing the HP, or you drive is causing the prop to slip. |
| All times are GMT -5. The time now is 06:49 AM. |
