-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   weight (https://www.offshoreonly.com/forums/fountain/18969-weight.html)
Daryl 02-26-2002 07:10 PM
weight
What is the dry weight of a 99 42 lightning? Was wandering if my dodge 1500 4wd would be able to tow it about 60 miles.THe truck does have the towing package. Thanks D.
Gunfighter 02-26-2002 08:40 PM
Marginal at best, be careful.
Dry weight is 9400lbs. Add 6 pounds for every gallon of gas you have on it, trailer and don't forget the usual crap every boat has, water..blah..blah. I bet your at 11K-12K pretty easy.
Mike
LPBoater 02-27-2002 11:27 AM
Daryl,
My 38 weighs 12,200 on the trailer with a half tank of gas. I had to tow mine home from the dealership with an F-150. Just make sure the brakes on the trailer work well on both sides. Also make sure when you stop it doesn't pull to one side. I adjusted the brakes out a bit before I started - It was not a comfortable tow!! The next week I sold the F150 and bought a 1 ton dually much nicer!!
LP
why wait 02-27-2002 02:47 PM
Daryl i had a 94 chev 1 ton. the 42 gave it a work out. the truck was a money pit after i got the boat. just took deliverie of a new d-max 1 ton hope life will be a lot easier.
