75-80 all day:drink:
Originally Posted by blownincome
(Post 2626943)
Ragged know where I can find a set of 28 Hydromotives The guy who bought my EX is looking for a set
The 28's might be a little steep, what power was in it? On my single step with 500s I ran 26 non lab Hydros and/or 28 Lab Bravos. About the same speed and RPM either way. I do have a set of 27 Hydro Q4s with a standard Bravo 1" hub that I would part with real cheap. I could also check at the marina this weekend, there were a lot of them there last I looked. |
27s is what he was looking for but I figured 28s might be easer to find I know he would take them off your hands Let me know ind I will hook you two up.Thanks!!!!! Bob
Originally Posted by RaggedEdge
(Post 2627158)
Send me a pm and let me know what you would cut them loose for. RAF |
Originally Posted by runafever
(Post 2627565)
RAF I believe they are sold to Blownincomes buyer, just talked with him an hour ago. Need to work out the details monday. If for some reason this does not happen I would get back to you, but I'm real sure it's a done deal. What I can do is check to see if there are any on the prop rack at the marina this weekend. Be glad to do that, can let you know what's available. |
Originally Posted by Marginmn
(Post 2626745)
Bo, just to refresh our memory, what should the toe be set at and how do we measure it?
Seem like the cones should be set 1/16th in or so if I remember. turning in should be 1/8 for single tie bar and 1/16 or dead even with a dual tie bar regardless. turning in= toe out, and turning out= toe in. center of bulett and center of prop shaft. you can use the pitot hole just above the the bulett if your running stock lowers |
my boss had an 05 or 06 with 496 mag ho's and was on the limiter at 79.????
Originally Posted by monstaaa
(Post 2628268)
center of bulett and center of prop shaft. you can use the pitot hole just above the the bulett if your running stock lowers Thanks Bo |
(Post 2628268)
center of bulett and center of prop shaft. you can use the pitot hole just above the the bulett if your running stock lowers Thanks Bo, guess I'll need to make an adjustment this weekend. What effect does it have on the boat? |
I am running 4 blade 32 I can't get over 70. thats what came with the boat should i try 28p
| All times are GMT -5. The time now is 02:04 PM. |
