Water from the cooler
Hi
I have a 29 Fever I just bought, when we used the cooler in the cuddy the floor got wet. After looking around under the sink I found that the hose was not hooked any where. Where is it supposed to go? Can I tap in to the hose from the bilge in the cuddy or tap in to the sink drain? |
I just pulled my cooler out to do a repair on the amp that is located below, and found the drain hose lays in the bottom and drains into the bilge. I did notice that it was curled up and was not laying on the fiberglass bottom, but on the carpet. It took some work to get it where it will drain into the bilge. We don't use the cooler for ice, only storage but I can see how it would have gotten the carpet wet. If you have enough pitch to hook it into the sink drain that would be a good solution.
Thank you,
I think i will tap it in to the sink, not sure i like water sitting in the bottem of the boat. The way the pump sits the water will remain there for ever. Michael |
cooler
you need to ad another fitting thrugh the hull beside the sink drain . if you run it in to the sink drain it still wil not drain right . it leave water in the line and it will stink very bad . trust me .
Thanks Tim
That make sence and and cleaner mike |
Originally Posted by Fever575
(Post 2636960)
Hi
I have a 29 Fever I just bought, when we used the cooler in the cuddy the floor got wet. After looking around under the sink I found that the hose was not hooked any where. Where is it supposed to go? Can I tap in to the hose from the bilge in the cuddy or tap in to the sink drain? I explain the whole deal. It probably wouldn't work to tie into the sink drain, that is the first thing that I though of also. The system is pretty simple and works pretty well if you understand it. Read my post in the other area that is lised. David |
Originally Posted by Dkahnjob
(Post 2697462)
See post number 5 on http://www.offshoreonly.com/forums/s...01#post2696301
Originally Posted by mcprodesign
(Post 2697555)
Are you going to ming?
Dave |
| All times are GMT -5. The time now is 09:22 AM. |
