best prop for 32 fever non step, 502 efi's
seen 69 on gps boat came with 26p Mach stern driver 4 blades, motors are fresh 50hrs, have been told could pick up a couple more mph with 3 blades believe I was on the rev limiter a Lil as well, I've only had it out once since I bought it, just curious of opinions
Originally Posted by jmoore1225
(Post 2691856)
Totally agree with paradise.
3 blade mirages are the prop but I'm spinnig 25's w/502's on a non-step 35. 27's might be to big.
Originally Posted by special reserve
(Post 2694590)
labbing will bring the rpms up, while turning the bigger blades... faster speeds result if the rpms are close to your peak power band.
In a perfect world, try stock 25 and 27's.. if the 27's are slightly too big, then lab. Carder |
I run 4 blade hydromotive props I have stock 502s with stainless marine exhaust and I run 79 on gps at 5250 rpm. it is a 2000 step hull.
| All times are GMT -5. The time now is 08:38 AM. |
