2000,32 fever w/ 502mags
i have been winterizing my boat, by suckin 10 gal of antifreeze through freshwater flush for a couple of years now(it works), because i physicaly can not reach the water presure and knock sensor by any means to drain block! how do the rest of you do it? and how do the good foutain dealers do it?
no help out there?
I did that this yr, only b/c i intend on having it test drivin and sold soon. But on a normal yr when im not selling a boat i will run antifreeze, fog engine, drain anti from system, and change both drive and engine oil.
Do you have a fresh water flush fitting where you can put a hose right into the sea-water system? I much prefer this method over muffs.
Most dealers do it with the muffs if you don't have a hose input. |
yes i run pure prop.glycol thru the fresh water flush sys. but i wish i could reach and pull fittings for knock, water, and cool fuel so i could make sure that there is no debris in the block and fuel sys! I was just curios how dealers do it for liability reasons, because i had a extremly small guy in there and he could not reach them either! know matter what way he contorted himself!
2000 33' :rolleyes:Sorry 32' thats more like it!1
oops yea that what i ment 32', just wish i had the new 33' what the subconcious does!
Originally Posted by 266ltd
(Post 2732358)
| All times are GMT -5. The time now is 10:09 PM. |
