-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Help setting up 2000 38' fountain (https://www.offshoreonly.com/forums/fountain/198547-help-setting-up-2000-38-fountain.html)
38 tally 11-13-2008 09:18 PM
the hydros are 5 blades
1stfntn 11-16-2008 11:40 PM
2000 38' Lightning with HP500 Carb's, slightly hotter cams, headers, stock Bravo I's (not XR's), 26 hydros (not labbed), spinning in, on the limiters. Run 81 - 82 GPS with two people and 1/2 tank of fuel. I would have expected you to be closer to 95ish with 700HP. Thinking of rebuilding my engines to 700 - 750 HP and adding XR's, so I am very interested in your results. Good luck; let us know how it turns out.
aTX427 11-18-2008 10:49 PM
ping Monsta, he built a very fast side by side 38 a couple years ago.
38 tally 11-21-2008 09:02 PM
sat was fun till i lost my starbord rotor.ran 32 p5 at 5100 at 84 not good. ran today with 29 p5x at 5700 at 90.5 better but still to much slip and needed a lot of trim around 6 or 7. i need a lot more help
any one set this up before.
H2Xmark 11-27-2008 02:49 PM
might try the p5x version of prop, also which way are you turning your props in or out?
38 tally 11-28-2008 10:15 PM
i ran props out and i ran 29 p5x at 90.5
38 tally 11-28-2008 10:19 PM
props in not out my bad
racinfever 11-29-2008 06:33 PM
38 Tally, I sent you a response in the prop section. You will be much better off with 4 blade and you will probably want to space down 1/2" to 1". Your small steps cannot be compared to the 2000 and newer boats with the bigger steps and higher x dimensions. The 5 blades always work better with high x dimensions but you are leaving speed on the table:( (Space down 1/2" to 1" 4 blade 29 Hydromotive or Bravo 1)
H2Xmark 12-01-2008 07:20 PM
try some 4 blade bravos, if it will get on plane ok then your drives are not to high, if it wont get on plane you will have to stay with 5 blades are add a spacer to lower your drive. also call throttle up and try some of there loaner props, see if they have any of there new 5 blades they make in house, that will give you what you are looking for
Wahoo ATV 12-10-2008 03:49 PM
Talk to Brett at Bblades he has done 100s of these. 920-295-4435.
