-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   fuel range? 29 fever with twin 454's (https://www.offshoreonly.com/forums/fountain/204289-fuel-range-29-fever-twin-454s.html)
TheFever29 03-05-2009 11:00 AM
im about to do a run with some of the guys from the ft myers offshore club and was wondering if anyone knows what the expected fuel range (miles) is on a 1998 29 fever with twin 454's and a 100 gal fuel tank?
i know i can just fill it up and run it and find out but the run is this weekend and i will do that then. just wanted a estimated range before hand from anyone that has a 29 fever with twin 454's. this way i can plan my fuel stop. thanks alot
BAJA WILL 03-05-2009 12:49 PM
Hard to estimate, How fast you going to run? Conditions? I guess to be conservative I would estimate .9-1.2 miles per gallon. I would plan on a refuel no longer than 80 Miles, at that point you can see how much fuel you burned.
I would rather fuel up and only be able to put 30 gallons in rather than run out.:ernaehrung004:
