Batteries and electical question.
Can anyone tell me which battery powers the cabin electronics and which battery is 1 and 2 on the switches. Should I have two deep cycles or should one of them be just a starting battery.
Batt 1 is the starting battery and 2 is the House (but in Fountain land that can change) but 9 out of 10 are set up that way
I have two switches and two bateries. Which is 1 port or starboard?
Yes, can someone explain this in detail? It does not explain itself....
My impression is that each switch supply power to the corresponding engine. (with 2 switches, 2 engines, 2 batteries) Starb. switch gives power to Cabin power panel Port switch gives power to tabs, trim. If I remember right, this is how my boat is set up. Correct me if I am wrong!! I get a bit confused some times when switching on. A good rule is to let one engine run on battery 1, and the other on batteri 2. When stationary, and with the stereo, interior lights etc. on for a long time, the other battery can start the both engines when switched to the 1+2 position. Am I right here? |
Bob , so how is mine ? battery port side for port engine and starbord battery for starbord engine ? do you leave both switchs on #1 ???? :ernaehrung004:
P switch to #2= P battery to the P motor,
S switch to #1= S battery to the S motor. Easy way to remember, each switch points to the side of the boat that it is on. LLL, RRR :) (switch, battery, motor) With both switches set to either 1 or 2, both motors will be starting off/charging the same battery. Not best to run them set to same position. And don't run both iswitches in the BOTH position. |
I'm am confused. have one switch to 1 and the other to 2 . is that corect ? :ernaehrung004:
Yes.
Pos 1 is for the S battery Pos 2 is for the P battery This applies to both switches. |
enjoy
Why not run the switch in "BOTH"?
[QUOTE=US1 And don't run both iswitches in the BOTH position.[/QUOTE] |
| All times are GMT -5. The time now is 09:32 PM. |
