-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   Charging Problem (https://www.offshoreonly.com/forums/fountain/207687-charging-problem.html)
35 White Lightning 04-27-2009 07:49 AM
Charging Problem
I am trying to narrow down a charging problem. Does the alts charge both batterys all the time, or only when the batt switch is in certain postions. I finally checked my batterys with a snapon tester yesterday 12.3 volts at 2000 rpm it seem like the only way the batterys went above 12 volts was when the switches were in both. I guess I need to check right on the back of each alt and make sure I dont have some corosion on terminals before I start replacing alts. Does anyone have a charging diagram on the charging system does the charge wire run over to the starter wire? thanks guys
gnorthga 04-27-2009 10:40 AM
I had a problem like that once it was the negitive black cables were coming lose from the terminals check all wires make sure they are not coming lose
