-   Fountain (https://www.offshoreonly.com/forums/fountain-37/)
-   -   500hps or Bulldogs (https://www.offshoreonly.com/forums/fountain/209110-500hps-bulldogs.html)
speedchangesyou 05-18-2009 07:37 PM
500hps or Bulldogs
Hey Guys how can you tell if your 500's are Bulldogs or not by the serial number........ thanks
RaggedEdge 05-18-2009 08:47 PM
Bulldogs and 500's are two entirely different engines. The Bulldogs are 540 CID while the 500's are only 500 CID. The serial numbers should tell you what you have.
jeff32 05-18-2009 09:41 PM
how many HP are the bulldogs ?
RaggedEdge 05-18-2009 10:30 PM
Merc rated them at 500 HP, same as the 500's. They were a stronger running engine though.
speedchangesyou 05-19-2009 06:09 AM
Difference
So who do I call at mercury to find out? Any phone numbers?
thanks
jeff32 05-19-2009 06:20 AM
serial number plus your local merc dealer
birdog 05-19-2009 08:00 AM
My Bulldog intake Manifolds have a 'TD" Cast after the brand Name..(tall Deck}
JaayTeee 05-19-2009 08:08 AM
The intake manifolds on the Bulldogs are black, the HP500's
are blue.
The flame arrestors on the Bulldogs say Bulldog
Bulldogs have a carb spacer under the carb,
HP500's dont.
speedchangesyou 05-19-2009 07:23 PM
bulldogs
Thanks Guys
aTX427 05-20-2009 09:13 AM
Get bulldogs if you can find them. They make the same power as the 500HP's, but will make a lot more power with a cam and heads.
